Please give us more info:
Which incubation temperature and time are you using?At what temperature is the inlet and detector?Are you working isothermal?Which liner type are you using? How much %RSD are you getting?
Atom
Chromatographic Parameters:
Column : ZB 624 column
(30 m x 0.53mm ID), 3.0 µm film thickness or Equivalent.
Injector Temperature : 250°C
Detector : FID
Detector Temperature : 300°C
Flow : 5.0 ml/min, constant flow
Carrier gas : Helium
Oven Temperature : 40°C for 5 min and then increased to 80°C at the rate of 5°C/min and then increase to 200°C at the rate of 10 °C per minute and hold at 200°C for 2 min.
Injection type : Split
Split ratio : 10:1
Headspace Parameters:
Vial Oven Temperature : 100°C
Transfer line Temperature: 120°C
Loop Temperature : 120°C
GC Cycle Time : 37 minutes
Vial equilibration Time : 10 minutes
Pressurization time : 0.15 minutes
Loop fill time : 0.5 minutes
Loop Equilibration Time : 0.1 minutes
Injection Time : 0.5 minute
Vial Shake : High
Loop Size : 1.0 ml
Headspace Vial : 20 mL
Preparation of Standard Solution:
Weigh accurately about 250 mg of n-propanol into a 100 mL volumetric flask containing about 20 mL of N,N Dimethyl formamide. Dissolve and dilute to volume with N,N Dimethyl formamide and mix well. 5.0 mL of the above solution transferred into a 50 mL volumetric flask and then dilute to volume with N,N Dimethyl formamide.
Transfer 2.0 mL of the solution into a headspace vial and seal the vial immediately.
Preparation of Sample Solution:
Weigh accurately about 100 mg of sample into a headspace vial. Add 2.0 mL of N,N Dimethyl formamide and seal the vial immediately and mix gently.
