After adding the internal standard, the RSD become worse
Posted: Sat Feb 29, 2020 5:49 am
Hi, I'm a graduate student and new to GC (about 1 year).
Currently, I'm working on to develop a method that can detect the trihalomethanes(THM) and haloacetic acids(HAA) at the same time by headspace SPME-GC/MS.
But I'm facing a problem as the title says... so here are the detail of my question.
Originally, I didn't add the internal standard(IS) to my sample. After three injections, RSD come up to be around 20% for each chemical.
As a result, I add the IS to improve the RSD. However, the RSD is getting worse with the adjust of IS! The result that is not adjusting with the IS looks much better!
I don't know what to do, I've checked the liner and septa, I think they look fine.
Please give me some advice!
Thank you so much.
Instrument:
I'm using Agilent 7890A GC-MS/MS with a DB-5MS column (60 m x 0.25 mm id x 0.25 um).
Thank you so much.
Instrument:
