5890 Fault
Posted: Mon Mar 23, 2009 5:24 pm
Hello everybody.
my 5890A´s display suddenly showed:
FAULT:
ADC OFFSET.
I read the manual and I found:
"Indicates a problem with the thermal ADC offset reading. Check R168 and R172 in the main board".
but before the problem another one had been happening: an unusual base line:
the detector was turned off.
Are these problems related each other?
Does the problem have solution without buying another mainboard? I mean, replacing components instead.
any suggestions will be appreciated.
many thanks
FAULT:
ADC OFFSET.
many thanks
