Hydrogen(H2) & Deuterium(2H or D) separation
Posted: Fri Mar 20, 2009 2:55 am
by tigerk2001
Hi everybody,
I would like to know the best column to separate Hydrogen(H2) from Deuterium(2H or D)?
I would prefer to use packed column.
thanks for your help
Posted: Sat Mar 21, 2009 1:29 am
by Don_Hilton
Off the top of my head, something like a PLOT column sould be a good way to go. A link to some information from Supelco is:
http://www.sigmaaldrich.com/etc/mediali ... 403146.pdf And a phone call to the tech support of your favorite column vendor may be of help.
Posted: Sat Mar 21, 2009 3:53 am
by Bruce Hamilton
My recollection is that activated alumina packed columns were typically used for separation of hydrogen isotopes. Examples used to be in old catalogues from packed column suppliers ( 1970s -1980s )
There are also alumina plot columns available, but I would start with a packed column. There should be plenty of literature from the 1960s and 1970s when many such isotope studies were performed.
Alumina chromatography behaviour is categorised by Brockmann activity ( mainly a function of residual water, IIRC ), so it would be very good idea to perform a literature search for the specific details of column preparation for the analysis.
Later Edit - An alternative technique is to use cryogenic conditions ( if your Gc supports them ), eg Molecular Sieve columns at liquid nitrogen temperatures. In my experience, cyrogenic conditions tend to be much more noisy ( both baseline and audio ).
A quick Google search " Gas chromatography hydrogen isotopes " found plenty of relevant literature on separation techniques.
Please keep having fun,
Bruce Hamilton
Posted: Sat Mar 21, 2009 10:03 pm
by tigerk2001
Thanks Bruce for the very good answer!!
Let me know if you can find some chromatograms showing separation of H2 isotopes.
It would be appreciate.
On my side I will check on google with the description you gave me.
gagne.dany@yahoo.ca
