Intersample custom field - Empower
Posted: Thu Mar 19, 2009 12:43 pm
by cholas
Does anyone know how to create and view results of intersample custom fields in Empower? As an example, I would like a custom field to calculate the absolute difference between the areas of 2 injections of sample.
Re: Intersample custom field - Empower
Posted: Tue Jul 28, 2009 6:28 pm
by cdsman1001
You can label one sample and create an inter-sample peak custom field to calculate the difference. The custom field can subtract the current sample minus the one that is labeled with a certain label. You can use CCompRef1 if you do not want the calculation to occur on all peaks.
