Chromeleon error message: Error P0040 value out of range
Posted: Fri Feb 14, 2020 11:36 am
I'm trying to run a sequenze in a Dionex ICS-5000, I'm using chromeleon 6.8. After creating the sequence, I click "ready check" in the menu Batch-start, and it gives an error message: Error P0040: Value out of range. I do not know how to find the value that is out of range. Detector compartment, column and cell heater temperature, pump pressure, suppressor current are ok. Can you help me?
