Weird baseline dips from gradient - Acquity TUV: anyone else
Posted: Tue Mar 17, 2009 4:54 pm
Has any user experieneced any similar problem to the .bmp file I have attached where they suddenly see odd dips in the baseline when running steep gradients on their Acquity TUV? if so how have you solved the problem or what could be causing it. Is it perhaps a detector / flow cell problem?
For everyone's info:
Black chrom: Acquity (MPA = Millipore Water + 0.1% TFA; MPB = Merck premixed AcN + 0.1%) dips @ about 9.9, 12.2 and 15.9 minutes
Green chrom: Agilent 1100 ( same mobile phase / column and conditions as black chrom) - no dips
Blue chrom: Acquity (MP A - millipore water + 0.1% TFA; MP B = Romil ACN + 0.1% TFA)
This could be probelematic trying to detect low level imps at 0.05% or less and the imp happens to elue at the point of one of these dips so a long term solution would be required.
[img][img]http://i43.tinypic.com/f4r28l.jpg[/img][/img]
