How do you know when the liquid nitrogen is low (DT-GCMS)
Posted: Wed Feb 05, 2020 4:47 am
I have a GL Sciences Optic 4 inlet and cryotrap. It runs on ~35 psi liquid nitrogen, but there's some level of liquid which is not enough to cool the trap to -140. The tank pressure gauge will read 35-40 psi, and the liquid level gauges rarely work.
Do you have a method or tip for knowing when you're about to have too little to run your trap?
I've consider a continuous read scale but am hoping there are simpler or better options.
