EPA 531.2 Help
Posted: Thu Mar 12, 2009 2:30 pm
by Bigbear
After running the above method on a 20+ year old Waters system my management has found funds to replace it.
I have recieved quotes from the following manufacturers:
Waters
Agilent/Pickering
Shimadzu
Hitachi
Anyone out there that have used any of these systems for EPA 531.2?
I would like to speak or converse with you if you have experience with any of these systems.
Thanks in advance
John
Posted: Fri Mar 20, 2009 9:42 am
by Hfranz
I work with this method quite a few and installed Pickering post-column derivatisation instruments in my previous job. The key to a successful n-methylcarbamate application is the selectivity of the column and the reliability of the derivatisation. Pickering does a good job on that.
What you need is an up to date analytical HPLC instrument. The large column provided by Pickering is more forgiving to extra column volumes required for a complete derivatisation of the analytes. Small Fast LC columns are no option for post-column.
You might go for any of the listed manufacturers, in addition I would like to suggests Dionex UltiMate 3000 HPLC be to considered. You will see, instrument and software are awesome.
Posted: Sun Apr 05, 2009 6:16 am
by XL
Here is the application note found in Dionex website which uses Pickerings post-column derivatization method on UltiMate-3000 HPLC system. http://www.dionex.com/en-us/webdocs/445 ... PN1935.pdf
Hope it will help.
