reversed phase ion-pairing of oligonucleotides
Posted: Tue Mar 10, 2009 9:57 pm
I've running some ion-pair experiments on synthetic oligonucleotides (~25 bp) using this Technical Note from waters. I'm sure at least one of you knows it.
https://www.waters.com/webassets/cms/li ... a20770.pdf
The HFIP/TEA gradient works very well (separated from N-1 to baseline) but HFIP is very pricey.
I tried the TEAA gradient but I can't achieve the resolution. I was wondering if anyone else had done any similar work with these ion-pairing systems and could recommend anything?
