Will column separate 20 different alkaloids?
Posted: Thu Jan 16, 2020 12:28 pm
So I'm just getting into column chromatography and I have a few questions. I realize they are somewhat novice, but I'm really interested and had trouble finding informative answers.
What I'm trying to do: Isolate quinine alkaloid from cinchona bark with the goal of eventually scaling it up.
1. Cinchona bark has up to 20 different alkaloids. If I dump a sample into a column, are they going to separate into 20 different bands of color? I'm asking this 'cause all the demonstrations I see show 2, maybe 3 bands of color at most.
2. From what I gather, column chromatography is the best way to get the purest quinine. What type of sample quantities am I going to be able to put through a column? Do I have to get an expensive prep chromatography machine if I want to do anything larger than a gram? Is there anything in between? What type of sample sizes can I put in a 40mm column?
I hope I don't come across as too annoying just trying to figure things out!
