Peak in Blank Injection-RS
Posted: Sat Mar 07, 2009 5:23 am
Hi guys,
In the blank(diluent) injection,for RS method of a NCE molecule, am getting a peak exactly at a RT(about 24 min.) of main peak.
Diluent is ACN:Buffer=1:1,
Buffer here is CH3COONH4+dil. CH3COOH.
I have tried no. of expts to identify its origin.
viz. variations in system,column,chemicals but is not successful.
No matter what is done , this peak is somehow not affected and it appears same in all cases.(area is almost same )
Column is YMC Pack pro C-18(150*3 mm,5 µm),
UV is 230 nm
flow rate is 0.5 ml/min for the gradient elution
Time A B
0 70 30
27 10 90
35 10 90
37 70 30
45 70 30
MP(A)- BUFFER
MP(B)- ACN : MEOH+dil. CH3COOH= 600:400+2.5 ml
Any thoughts will be highly appreciated...![/quote]
UV is 230 nm
Time A B
0 70 30
27 10 90
35 10 90
37 70 30
45 70 30
MP(A)- BUFFER
