Adduct in third Quad?
Posted: Tue Mar 03, 2009 11:19 pm
I am working on a compound that is 152 amu. Infusion of this compound does not yield the appropriate ion but does yield an ion at 175. This appears to be my compound with a sodium adduct. My usual attempts to isolate the compound have not worked so I optimized on 175. The compound is a ethyl-R with R being 96 amu. Upon optimization it yielded a product ion of 119. Now could the 119amu be my 96+23amu and the sodium adduct has carried through in the MS/MS method on the product? I have never seen this before and think it's impossible but could I be wrong? Has anyone seen this sort of phemomenon? typically I do everything in my power to not monitor compound+adduct and have only done it a few times when following a method that expressly says to.
I will attempt to infuse this tomorrow using heated nebulizer in attempt to eliminate this adduct but has anyone seen this before?
