E2M2 making intermittent grindng noise
Posted: Thu Dec 19, 2019 4:18 pm
by MSCHemist
The Foreline pump (E2M2) is working fine but intermittantly it makes a very loud grinding noise that seems to be coming from the fan area that goes away after a few seconds. It sounds like a bearing is failing. It is very loud and driving me crazy. I am looking at the exploded parts diagram but can't figure out what part needs to be replaced and how to attack it.
I checked and replaced the oil it looked fine, a bit yellow but nothing suspended in it.
Re: E2M2 making intermittent grindng noise
Posted: Thu Dec 19, 2019 5:30 pm
by MSCHemist
I've determined it lost the headless bolt from the motor coupling and fan assembly. Trying to figure out how to get it back.
Posted: Fri Jan 03, 2020 10:42 pm
by LALman
Mine which was old back in 2001 began making a periodic grinding noise and it turned out to be the motor bearings. They were letting the plastic fan on the coupler grind against the case. I got the motor rebuilt and that took care of it.
Posted: Tue Jan 21, 2020 1:32 pm
by MSCHemist
I think I fixed it. I took the entire coupler/fan off, cleaned the pad, got some silicone down the motor shaft and put it back together. It has been fine since. I think some gritty oil got in there. It leaks a very minute amount from the oil tank gasket.
I had an old E2M1.5 lying around that I took apart. Not as bad to service as I thought. The exploded parts diagram looked scary but there were only a handful of really lose parts when I took apart the modules.
Posted: Wed Jan 22, 2020 10:50 pm
by James_Ball
Glad you got it working well again. I have yet to do anything to an E2M2 except change oil even on the ones that are 30 years old and they only weep a few drops per month. I have an RV5 that is a few years old and leaks like the Titanic, gonna try to replace the tank seal on it soon, wish me luck.
