Cyclohexene in MeCl2 used in GC/MS
Posted: Sat Feb 21, 2009 3:47 pm
We were developing a method that involved the GC/MS analysis of 2-pentanone. We were using methylene chloride as the solvent. We found what appeared to be a contaminant at the ~50 ppm level in the methylene chloride. The mass spectrum of this compound matched that for cyclohexene. Using the NIST RI database we found that cyclohexen has RI values in the range of 701 to 657. The RI values for 2-pentanone are in the range of 716 to 645. This corresponded to our results which has these two compounds coeluting.
We did a Web search and found a couple of articles talking about cyclohexene being used as a stablizer in methylene chlorie. There was no indication on our reagent bottle that this was the case for the material purchased. When we checked the Aldrich catalog, we found listings for methylene chloride which is stablized with amylene which has RI values in the range of 425 to 514.
I would like to know if anyone else has had a problem with cyclohexene in methylene chloride and if changing to methylene chloride stablized with amylene solved the problem. Was in necessary to oxidize the cyclohexene and distill the methylene chloride to separate out the oxidized product to get pure methylene chloride.
Thanks for anything you might know about such a situation.
