Sorbic Acid in Wines
Posted: Sat Nov 30, 2019 4:09 am
by laxutraly
Hello
I analysed sorbic acid and benzoic acid in wines using HPLC.
Between those two peaks, appears another peak, but I don't know what analyte is this. Please, could someone help me?
Mobile phase:
70 % acetate amonium buffer (0,4 g/L) pH 4,5 (ajusted with acetic acid)
30 % acetonitrile
wave lenght = 254 nm
The samples are diluited 10 x.
column C18
Thank you!
Re: Sorbic Acid in Wines
Posted: Sun Dec 01, 2019 4:58 pm
by HPLC chemist
I always distilled (Kjeldahl microdistillation apparatus)my samples into water before HPLC in order to eliminate sample matrix effects. So I have no idea!
Posted: Fri Dec 27, 2019 2:04 am
by JI2002
The unknown could be identified by QTOF LCMS.
