Retention time shortened abruptly
Posted: Wed Feb 18, 2009 2:27 am
Hi. I'm pretty new in HPLC. I'm assigned to separate 2 DNA fragments (300bp and 2500bp) using HPLC.
Recently I encounter a problem whereby my retention time shortens by about 7 minutes. Not only that, initially there were 2 peaks coming out (at 24 and 29 min) but, with the same sample, same gradient, pressure and flow rate, now the peaks overlapped and come out at 17.5 min.
What could be the reason for this abrupt change in retention time? What should I do to separate the peaks?
