glyphosate analysis
Posted: Wed Feb 18, 2009 12:45 am
Hi
Does anyone test glyphosate using anion exchange conductivity detection, I'm having problems with this.
I'm using a waters anion HC column with a Alltech 320 detector. With borate/gluconate buffer 2ml/min isocratic 4.6 X 150mm col.
The HPLC system is working fine for other UV based tests but there is no column temperature control. It has been passivated and most of the fittings are peek. I'm having problems with drifting baselines and poor reproducibility (5-10%) within runs. I can't use the analyses.
My chromatography looks OK correct retention time nice peak shape.
I suspect that the detector may be the problem. I haven't had any previous expereince with this type of detector with most of my previous HPLC work being UV based or MS. No one else I know has used it before much either.
Any suggestions would be welcome before I send it out to be checked. I usually do most of my own troubleshooting and maintenance but this one has me stumped.
Changing the method is not an option as it has been validated and besides the cost of buying in an ELSD detector (my prefered option) isn't viable at the moment.
Regards
Kerrie
Regards
Kerrie
