Problem with IP-RP HPLC column
Posted: Mon Feb 16, 2009 6:17 pm
Hi all,
I'm using silica column (Varian Helix). Some time ago 'something wrong' started to happen - peaks from the shortest fragments of DNA standard (pUC18 digested with HaeIII) became small and doubled. I washed the column with 0.5M disodium EDTA according to Varian's instruction and after that the column completely broke down.
Washing with ACN-THF-ACN composition didn't help.
Do you have any idea:
1) what happened?
I wonder if it could be due to any contamination in the water used to analysed PCR and EDTA solution making (detergents from dirty glass bottle?) Or maybe I destroyed the column with too high pH (that's the suggestion of my colleagues, who work on Waters silica columns)? My buffers are quite old, with measured pH=7.4 (whereas Varian specifies its buffor pH 7.0), EDTA solution pH=8.0.
2) what else I can do?
Thanks.
1) what happened?
Thanks.
