antique equipment - HELP nonsuppressed ion chromatography
Posted: Thu Feb 12, 2009 4:20 am
Hi
I'm just working part mine doing some basic quality assurance while the kids are little. Nice boss but old old equipment.
I have an waters 510 pump, waters 481 UV detector and alltech 320 UV detector using manual injection. Using a shimatzu CR6A chromatopac integrated plotter.
I am having trouble with the integrated plotter when using it for non suppressed ion chromatrography. Because the peaks are broad (method not chromatographic problem) the plotter does a poor job of calculating the peak area. It is fine with UV detection and the narrower peaks.
Is there any Cheap way to hook up these detectors to a PC and use some shareware to analyse the data. As long as I can get the correct peak areas out I'd be happy even if I have to manually pick them myself.
Kerrie
Kerrie
