Running 3 mm ID columns on Standard LC Systems
Posted: Wed Feb 11, 2009 4:51 pm
Here's a question.
Due to the ACN shortage - or just to save solvent in general - one approach is obviously to use a smaller ID column. But we know that when you use a 2 mm ID column on a standard HPLC system you usually have problems: mostly because the volume of the detection cell is too large (other extra-column effects can be controlled).
So my question is: what about 3 mm or 3.2 mm columns. Are these OK on "standard" HPLC systems or do we need to replace the detector cell?
Much Thanks in Advance.
