Power Failure GCMS
Posted: Tue Oct 29, 2019 3:32 am
I have been collecting data for the last few months and was getting close to wrapping up my first project until we had a power outage last week. The power went out for around 20 minutes to the GCMS, and since then the instrument has not been operational. Below is an example of the same sample ran before the outage (black) and after the outage (red, blue, pink).
https://drive.google.com/file/d/0B6JoSk ... sp=sharing
As can be seen, the baseline is higher, the sensitivity is way lower, and there is no symmetry. This leads me to believe that there was an issue with the mass spec so I did a full tune today. I will attach the tune report. When I look at this report nothing stands out to place the instrument in such an unfunctional state. Can you please advise anything you think I can do to it? Does the tune report indicate any damages by the power outage?
