QuicK QUESTION-----HOW IS HPLC USED TO TEST FOR SICKLE CELL
Posted: Fri Nov 05, 2004 8:43 pm
by kmata85
IM DOING RESEARCH ON SICKLE CELL AND THE HPLC TEST CAME UP. I JUST WANTED TO KNOW WHAT IT IS AND HOW IT IS PERFORMED.
THANKYOU, KEL
Sickle Cell HPLC Test
Posted: Sat Nov 06, 2004 10:35 pm
by Chris Pohl
kmata,
This test is based on cation-exchange HPLC (a technique for separating molecules based on the distribution and quantity of positively charged sites on the surface of the molecule). Patients with sickle cell anemia have one of several variants of hemoglobin that are different from hemoglobin found in normal patients. Since these variants are slightly different in shape as well as the magnitude of positive charge under a defined set of conditions, these variants can be separated and detected based on the rate at which they pass through a cation exchange column. Bio-Rad (http://bio-rad.com) sells equipment and analysis kits for this application. You might find more about this application there.
