Page 6 of 8
Re: Embedded PC not responding - Waters Quattro Micro
Posted: Tue Feb 25, 2020 10:00 am
by Bram
Dear Jörg,
I am struggling with the same issues. Might you be willing to provide me with the instructions mentioned before?
my email: bramvandeput (at) gmail (dot) com
Much obliged!
Bram
Posted: Tue Mar 10, 2020 8:35 pm
by bunnahabhain
Dear Bram
I am at parental leave at the moment with no access to my work stuff. I will be back in April and most likely wil have forgotten this thread...
Maybe one of the others can help you out, if not post this question again mid of April, I will be able to respond more helpfully then.
See you
Jörg
Posted: Sun Oct 11, 2020 7:16 pm
by escu
Hi, we have a waters qtof micro, also old hdd died, managed to install a new pc, masslynks 4.1, configured ftp, but we need a small update SCN 795 which provides the file MA3778_1.pci which is the vxworks driver for MA3778-200 IsoProbe PCI DACs board.
Anybody has SCN 795 or any other SCN with the file "MA3778_1.pci", or at least this file on the hard drive ?
Thanks!
Posted: Tue Oct 20, 2020 11:13 pm
by nkg
I have 4.1 scn795, let me know your details and I'll send it over
Posted: Thu Oct 22, 2020 10:15 pm
by escu
Thank you, meanwhile I managed to purchase a DVD with scn795 from waters. But now it does not boot at all, fails loading Socket.out with with error "could not allocate segments", ld error: error reading file errno 0x3d0001
In the pdf with release notes for SCN 795 it says that this update provides support for a new operating system on the embedded PC, VxWorks v6.3 ! But my embedded computer runs VxWorks 5.4.2, kernel wind 2.5.
The Operating System on the embedded computer is loaded from a flash installed in the embedded computer ? Or that flash contains only a boot loader, and VxWorks OS and the drivers and startup script are loaded all from the windows PC through FTP ?
Posted: Thu Oct 22, 2020 10:22 pm
by escu
What VxWorks version and Kernel is your embedded system running ?
Posted: Thu Oct 29, 2020 10:06 am
by nkg
I haven't got this running on a ms, only have the software
Posted: Thu Mar 04, 2021 3:23 am
by MassMan
The EPC is looking for it's operating system on the workstation's ftp server: You have to properly set up the ftp server and the user "micromass", the EPC will constantly reboot and try to connect.
Leave your e-mail address and I'll send you an instruction document how to do that.
Regards
Jörg
Jorg-
Like so many others, I need help with connecting a host PC to a Quattro Micro. The epc reboots about every 2 minutes. I can successfully "ping epc" but i can not telnet to it. Reading here, it sounds like my problem is with the host PC.
Would you be willing to share you instruction document with me too? Thanks.
Posted: Thu Mar 04, 2021 8:03 am
by bunnahabhain
MassMan, please leave your mail address, I will then send you the instruction documents.
Kind regards
Jörg
Posted: Thu Mar 04, 2021 1:06 pm
by MassMan
Jorg-
Thank you!
Posted: Thu Mar 04, 2021 4:22 pm
by bunnahabhain
Mail is on the way. Be sure your spam filter does not eat it, it contains one .doc and ont .ppt file...
Posted: Thu May 13, 2021 8:56 am
by hamid_a76
Post your e-mail, I will drop you a mail containing the step-by-step setup instructions.
Jörg
Hello
Like the others ,i need help to connect a Quattro Micro to PC
can you send me this instructions and any manual about Quattro Micro if its available .Thanks a lot
my email is
hamidah1344@gmail.com
Posted: Wed Apr 13, 2022 11:57 pm
by kaputmi3
Hi all,
I'm in the same boat here. I cannot even successfully ping 64.1.1.1 (let alone 64.1.1.2!), which seems like it should work as long as the FTP server is running on my computer. I've tried following many online resources but am nonetheless stuck.
Any help would be appreciated! My mass spec is a micromass qtof.
Posted: Thu Apr 14, 2022 7:17 am
by bunnahabhain
If you cannot ping 64.1.1.1 you network card is not configured correctly. This has nothing to do with FTP at this stage.
Be sure that the instrument LAN card is set up as fikkiws:
Primary IP 192.168.0.1 // subnet mask 255.255.255.0
Secondary IP 64.1.1.1 // subnet mask 255.0.0.0
Good luck
Jörg
Posted: Tue Aug 09, 2022 10:56 am
by MrGC
Dear Jörg,
could you send me the instructions as well, please?
email:
beatzmaen@aol.com
Best regards
