Re: Sucrose analysis
Posted: Mon Mar 10, 2014 5:25 pm
If you look at the Amide application note book you will see that when they use 0.2% TEA in the mobile phase they run at 35C. When they run at high tem they run at much lower concentration of TEA... I always suspected that was because of column life issues at h igh temp at high pH
I suspect that is what is happening with your columns
