Re: Alcohol Method Development by GC-MS
Posted: Tue Apr 28, 2020 2:28 pm
Have you developed a method?
I have the same problem and like to hear how I can solve this.
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
https://www.chromforum.org/
I am having difficulty extracting all of the alcohol from hand sanitizer products in the form of a 'gel'. While it appears the gel fully dissolved in water, the results of my alcohol content say otherwise. Did you always use water as your solvent and have you ever tested a gel matrix? If so what solvent did you use?
Our hand sanitizer products were over 60% ethanol, but in our validation studies boss made us go down to extremely low levels, even those would be so many orders of magnitude less than our target levels. He was "afraid" of ever having to answer a question should an auditor ask.
Our alcohol-containing products were hand sanitizer gels; we always used water as the solvent, and had no issues with our assay. We also cGMP-validated the USP procedure, adapted for our gel finished product, our pointy-haired boss demanded that.I am having difficulty extracting all of the alcohol from hand sanitizer products in the form of a 'gel'. While it appears the gel fully dissolved in water, the results of my alcohol content say otherwise. Did you always use water as your solvent and have you ever tested a gel matrix? If so what solvent did you use?
Measuring by weight would be easier than trying to pipette a specific volume. But then how would you get your result in v/v%? the only way I assume would be to know the density of the gel.Our alcohol-containing products were hand sanitizer gels; we always used water as the solvent, and had no issues with our assay. We also cGMP-validated the USP procedure, adapted for our gel finished product, our pointy-haired boss demanded that.I am having difficulty extracting all of the alcohol from hand sanitizer products in the form of a 'gel'. While it appears the gel fully dissolved in water, the results of my alcohol content say otherwise. Did you always use water as your solvent and have you ever tested a gel matrix? If so what solvent did you use?
Production QC also had no issues with the procedure.
There were some potentially proprietary sample preparation innovations we developed to aid in the analysis of a volatile analyte accurately. One involved weighing 3 gram sample into a volumetric flask already containing about 50 ml water.
Confirming that measuring by weight seemed to have worked and using online tables to convert w/w to v/v% can be found. Thanks!Measuring by weight would be easier than trying to pipette a specific volume. But then how would you get your result in v/v%? the only way I assume would be to know the density of the gel.Our alcohol-containing products were hand sanitizer gels; we always used water as the solvent, and had no issues with our assay. We also cGMP-validated the USP procedure, adapted for our gel finished product, our pointy-haired boss demanded that.
Yes, we knew the density of the alcohol gel product. Our product also had tiny air bubbles entrapped in it, marketing gimmick. Due to the gel nature of the product, would've been difficult to sample by volume; taking a relatively large sample size of 3 grams provided made any potential randomness of the air bubbles negligible, and was relatively fast way to sample.Measuring by weight would be easier than trying to pipette a specific volume. But then how would you get your result in v/v%? the only way I assume would be to know the density of the gel.
please describe the results
First thing you need to do is define for yourself what "alcohol free" means to you or to your company. For example, would one molecule of alcohol mean that the product is not truly "alcohol free" ?Hello everyone,
this topic is interesting to me because I want to confirm that "alcohol-free" cosmetic cream is really free from alcohol. I planed to analyze it on GC-FID but I am not sure how to prepare the sample so I can extract alcohol (if there is any) because the cream matrix is oily? Any experiences or ideas?
Thank you in advance.
For something like that I would think the Rxi-624-SilMS column would be better. It has good separation for low molecular weight analytes and a max temp of about 320C.I'll just add that using a DB-VRX column to do alcohols is possible but I would worry about the hand cream composition. You don't want semivolatiles in the handcream getting on a column that has a max temp of 260C.
Molecular weight is 32amu, but major ion from EI is 31amu. It is still difficult to go very low if there is any oxygen present, but not impossible to do. FID though I think will give better detection limits since it is more sensitive to methanol than MS and no interference from oxygen.I thought methanol was impossible to do via GC/MS you need an FID. The molecular weight of methanol is 32amu which is also the molecular weight of O2.
I do ethanol via headspace GC/ms. I use acetonitrile as the internal standard and use full evaporative. I put 10ul into a 10ml vial and heat to 120degC for 10 minutes. If I am doing an oil soluble sample I use acetone instead of water. I use a 0.5df wax coln though I am told 1701 or 624 works better.
