Posted: Thu Dec 11, 2008 5:04 am
You want to stay 2 pH untits away from the pKa of your analyte to get the most reproducible chromatography. Trouble is that pH and pKa shift each by as much as 2 units when you add organic solvent.
The best approach is to make a buffer (in water) that has the highest buffering capacity and does the intended separation. The rest is simply method control.
With respect to the development of a method, the knowledge of the pKa of the analyte(s) is only of secondar importance.
