Posted: Thu Jul 10, 2008 2:26 am
Well it seems to have calmed down a fair bit and the baseline noise is around 20 uV. Baseline rise over the course of a 100'C program is about 900 uV, which is acceptable. So I've started my sample runs. I'd say we've got gases which are right at the bottom of acceptable purity limits, hence the garbage we see on the baseline. Air Liquide will be put on notice
Ron, the baseline rise and spikes have nothing to do with the column. All of the pictures posted above were screenshot while the column was disconnected, so it's entirely FID noise. Anyway, while the signal might look fine to some, I have got far, far better chromatography out of the old 17A right next door.
Will let you all know how we get on.
Cheers,
CHRIS
Cheers,
CHRIS
