Posted: Tue Feb 26, 2008 7:25 am
Hi Adam
The problem with keeping the flame lit with 450 ml/min of air suggests something not right with the flows in the detector. Check the following: no obstructions in the flame tip and that the end of the column is not actually through the hole in the tip, that the flame tip is properly seated in the injector base, and that the gas supplies are connected to the right pipes - you might be putting air through the jet or something.
