In the article I linked to, all these issues were covered. In particular, the very first step in the adaptation process is to calculate the resolution of the critical pairs and see what effect Fast LC will have. If the theoretical resolution of the modified program is unacceptable, stop right there. It takes 10 minutes to 1 hour to do the math, then you will know whether it is right for your application.
