Page 2 of 2
Posted: Thu Oct 26, 2006 3:02 am
by Uwe Neue
I agree with Promochrom. You may have better luck with a high organic concentration in your sample solution, i.e. use HILIC...
Posted: Fri Oct 27, 2006 9:49 am
by Patrik Appelblad
I agree with the last two posts. HILIC would be the next logical step.
Pyridoxal, an analogue to compound A, is eluting at 6 minutes on a 15 cm ZIC-HILIC column, using ACN/NH4-formiate 10mM; 90:10 V/V as mobile phase. I would expect B and C to be more retained.
Posted: Fri Oct 27, 2006 12:46 pm
by anupama
You can find pka value for compound and according to that you can adjust pH or you can use ion pairing reagent.May be it can help.
Posted: Thu Nov 02, 2006 12:15 am
by syx
I still try this and that... please be patient to wait the result...
Posted: Mon Nov 13, 2006 8:27 am
by syx
We found no problem when inject methanolic solution of dipyrone. The stability is ok. But when we mixed with thiamine and pyridoxine, dipyrone was degraded! I think there is reaction between them...
