Posted: Mon Apr 10, 2006 11:40 am
YM,
It seems the difference is setting of PDA detector and UV. Could you pls check , if you are using any reference wevlength in your PDA?? if yes turn it off and rerun your samples. I have seen if your peak of interest fall between reference wevlength range it will not show in PDA, whereas in UV there is no such setting.
JM
JM
