Posted: Wed Jan 04, 2006 1:40 am
I’ve found recommended storage for degasser from its instruction manual. When leaving the degasser unused for a long time, the flow path should be cleaned with distiller water adequately, fed with methanol, and replace with the clean air for drying.
There is indicator light in our degasser. When we returned to work after a week Christmas-new year vacation, we found that abnormal vacuum system led was turn on
. It turned to normal indication after 1-2 days of usage. I did not find any explanation about what kind of abnormality will be appeared when there was solvent in the flow path during storage. Why should it be kept dry?
