Shoulder in methanol peak
22 posts Page 2 of 2
Thank you!!
I'm learning a lot from all of you.
I will apply the changes you suggested and post the results.
Michael.
Hi Michael
Great
As a note of caution, just change one thing at a time to understand what is happening.
Perhaps try your 4mm liner with 100uL/sec injection speed splitless first, keeping all other conditions the same.
Ralph
Ralph
Thank you.
I will probably have the results by tomorrow.
Michael
Hi Michael
I am not sure of your time zone but if that doesn't work (or even if it does) try also, if you have the time
4mm liner with a 10:1 split and 100 and 500uL/sec injection speeds to compare.
Ralph
Ralph
Hi Michael
Did you get a chance to try the changes?
Feedback to the forum members would be appreciated.
Kind regards
Ralph
Ralph
Sorry that i didn't get a chance to post.
I tried with a 4mm liner:
with injection speed of 100ul/min the shoulder got worse!
with injection speed of 700ul/min the peak shape improved but the shoulder is still noticeable.
I didn't get a change to try split injection.
I will probably try again in the next two weeks i hope because i don't have access to the GC right now.
And again sorry that i didn't post.
I will update as soon as i have a chance to try again!
Hi Michael
Thanks for keeping us updated - looking forward to hearing your split injection results
Ralph
Ralph
In total there are 82 users online :: 1 registered, 0 hidden and 81 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 81 guests
