Page 2 of 2
Re: injection without autosampler
Posted: Thu Aug 21, 2014 1:02 pm
by vikiBPI
Hi Tomasz,
The z-belt inside the autosampler arm is torn. Additionally one little gear wheel that supports the z-belt is totally worn down. Unfortunately the geer wheel is not an official part and therefore there's no supplier for it
Now I'm looking for a second hand autosampler arm (also for its replacement parts) but that's not easy to find either...
Regards, Viki
Posted: Thu Aug 21, 2014 2:38 pm
by Peter Apps
Hi Tomasz,
Regards, Viki
Hi Viki
Most instrumentation is assembled from standard parts that the manufacturers buy in. It is a while since I looked, but try Googling something like "small parts" and "small components" and you will be astonished at how much of a GC you can put together ! It may take a while to find the right wheel, but you can do it during the 25 minutes between semi-manual injections ! Good luck.
Posted: Fri Aug 22, 2014 9:45 am
by Forse
It is very easy to get a machine shop to produce a new gear wheel. If nylon will do it will probably also be cheap.
Posted: Fri Aug 22, 2014 11:00 am
by Peter Apps
Hi Tomasz,
Regards, Viki
Hi Viki
Are you sure that the wheel is really worn smooth and that it was not smooth to start with ? - it might just be an idler wheel to guide the belt or keep it under tension.
Posted: Fri Aug 22, 2014 4:37 pm
by AICMM
Viki,
Spare trays are readily available and (usually) reasonably priced. If it were just the belt I would say talk to Restek but since it is also a wheel I would advise buying a used tray and then keeping yours for spare parts.
For the non-adventurous, there is the Merlin Micro-shot for manual injections.
Best regards,
AICMM
Posted: Fri Aug 29, 2014 11:34 pm
by MSCHemist
Yep you should be able to get a replacement gear if you know the dimmensions.
Normally they do use standard parts though they are not always easy to obtain. I am working my Tekmar 7000. A few of the gear motors could use replacement [one is totally shot] but Tekmar only sells whole assemblies for $900 a pop and the motors themselves are made locally by a company name Merkle Korff but they won't sell to individuals and have a minimum order of 100 so noone has them stocked arround. I manged to find the one I most need NOS.
Posted: Sat Aug 30, 2014 7:04 am
by Peter Apps
If you can find any kind of identification -serial numbers especially - on a part that needs replacing it is always worth a shot to just Google it - I am continually amazed by what I can find.
CH
