Page 2 of 2
Re: novice questions: why is my chromatogram periodic?
Posted: Wed Mar 26, 2014 7:37 pm
by glenchung
Cool idea for the 1-mL syringe, thanks very much Peter, I will do it.
Posted: Wed Mar 26, 2014 8:31 pm
by James_Ball
Peter has a good idea there.
The only other option with a 1ml syringe would be doing headspace analysis. Take a few drops of gasoline and put it into a 10-50ml vial with some type of septa, allow it to evaporate, then pull 1ml of the gas from the headspace in the vial and inject the whole 1ml of gas slowly into the injection port with the column at about 40C, then ramp to about 250C over 15 minutes and look for the pattern to appear. If you are doing this for demonstration purposes in a school chemistry class that would be a good experiment also.
Posted: Wed Mar 26, 2014 9:13 pm
by glenchung
Wow, another cool idea. James_Ball, would that headspace routine be repeatable? Is this something that you industry types do often, for quick and qualitative analyses?
Posted: Thu Mar 27, 2014 1:30 pm
by rb6banjo
Headspace analysis is all I do - pretty much. I have found that manual injection headspace analysis can be somewhat lacking when it comes to reproducibility. Autosamplers designed for headspace analysis help to improve this.
Typically, to get good results from a quantitative standpoint, you need specially designed vials where your sample is contained inside, there is a septum on the vial that you can pierce with the needle of your syringe to extract the sample. Most of us use something like this:
http://i1285.photobucket.com/albums/a59 ... 39b231.gif
The cap is a piece of aluminum with a hole in the center. A rubber septum (gasket) fits tightly in the cap and is crimped down on the flange of the glass vial. The rubber gasket seals the sample inside and allows a path for the syringe needle to get into the vapor space of the vial to pull out a sample.
There are other sizes. You can use other things as well. If you are just doing qualitative analysis, you can inject into a ziploc bag that contains your gas sample (go grab some exhaust from a car in the parking lot, don't burn yourself!!!). Throw some flowers in the bag, let it sit for a while, then reach in with the syringe and get a sample of the gas. There are other things you have to worry about when you use polymeric bags, e.g., does the bag absorb or react with your analytes?, etc. You are only limited by your imagination.
I wish my high school would have had a GC when I was there.
Posted: Thu Mar 27, 2014 1:37 pm
by glenchung
Those are fabulous ideas, rb6banjo, thank you very much. I will try the car exhaust idea somehow.
Posted: Thu Mar 27, 2014 1:43 pm
by rb6banjo
You're welcome. Like I said, don't burn yourself. That pipe gets really hot if the car is on for a while.
Posted: Thu Mar 27, 2014 2:55 pm
by KM-USA
We've put an (unused) non-lubricated condom over an aerosol can, then sprayed itno that to get gas sample for GCMS to determine which propellant was used.
Posted: Thu Mar 27, 2014 5:33 pm
by rb6banjo
That's very creative!!! I wouldn't have thought of that one.
Posted: Fri Mar 28, 2014 7:11 pm
by James_Ball
I can just imagine the reaction from a room full of teenagers when you try that one :)
Posted: Fri Mar 28, 2014 7:19 pm
by Steve Reimer
Who needs Tedlar bags anyway?
