Page 2 of 2
Re: Varian Prostar 335 error
Posted: Tue Jan 19, 2016 6:34 pm
by RogueResearch
I recently built a Varian 335 HPLC system running MSWS 6.41 workstation. I also have a 325 detector. I understand I need a program called Polyverify to perform higher level maintenance tasks on the 335. I was wondering where this program could be found and if it will also work on the 325 (or does the 325 require not poly just Verify)? Many thanks in advance!
Posted: Tue Feb 07, 2017 9:05 pm
by RogueResearch
I can get you a copy of the PolyVerify software if you want. Give me your email address or dropbox and I can send it to you in a couple days.
Also, you might want to try and re-calibrate the lamps to fix the CC Slit line peak error.
Hello-
I was wondering if you still had a copy of PolyVerify? I have a 335 I would like to keep running.
Thanks!
