I know what you mean about the transient air and water peaks when the PFTBA valve is first opened, it just takes some time to equilibrate. After my dead time run everything is back down to 1% or less. I don't really try to chance anything down unless there is an obvious air leak causing high pressure in the quad chamber or if the air signal (N2 m/z=28) gets above 2-5%
