If you want a degree of accuracy you really need to keep as many things as possible the same between your samples and calibration standards, but ultimately the detector detects whatever reaches it. It's easy enough to calculate the weight of analyte in e.g a 1ul liquid injection at a conc of say 100ppm then work this back from whatever response you get from your gas samples to give your gas composition.
