Ion Pair Behavior
Posted: Sun Apr 17, 2005 12:30 am
Sorry, but because I've been doing research in this area for more than 25 years-I feel obligated to confuse matters further by adding an additional fact that flies in the face of the dynamic ion exchange hypothesis. While I previously mentioned the fact that the counterion effect is not predicted by the ion pair model, there is also a major experimental observation not readily explained by the "dynamic ion exchange" model: the amount of the ion pair reagent absorbed on the surface is counterion dependent, even in a case of counterions which are unlikely to be able to form ion pairs because of extreme hydrated radius (e.g. fluoride and chloride counterions of tetrabutylammonium ion). In a paper by Frederic Cantwell (Cantwell et al., Anal. Chem. 51 623 (1979)) from about the same time as the paper from Bidlingmeyer and the paper from Horvath, the presence of the electrical double layer at the surface of the stationary phase is proposed as an explanation for the observed behavior with "ion pair reagents". This model explains both the counterion effect and the variable surface concentration of the ion pair reagent without requiring a postulated "ion pair". The counterions are present in the diffuse region of the electrical double layer and allow for the effect of these counterions on the retention process. In essence, an ion which allows for a more condensed electrical double layer will allow a correspondingly larger concentration of the ion pair reagent to be present on the surface of the stationary phase. The "dynamic ion exchange" model is insufficient to explain this effect (it predicts that retention would be counterion dependent but does not predict that the ion pair reagent surface concentration would be variable).
To cloud matters further, here is a "bone" for those of you who prefer to think of this retention mode in terms of ion pair formation. The physical chemistry at the surface of a hydrophobic material leaves open the possibility that while ion pairs may generally be unlikely to form in the mobile phase, they may well be present in the stationary phase. For example, in a previous post I mentioned a paper which showed that a dielectric constant of less than 43.6 was required in order to have any measurable ion pair formation in the case of tetraisoamylammonium nitrate. In that specific case, more then 76% methanol or more than 86% acetonitrile are required in order to achieve that dielectric constant. While such conditions are uncommon in ion pair chromatography, the dielectric constant of the stationary phase under conditions commonly employed in ion pair chromatography might easily be below that critical limit. For example, the dielectric constant of the stationary phase in the case of C18 bonded phase silica is a function of the bonded phase, the solvent content and the water content. Although I'm not aware of any specific stationary phase dielectric constant data measured under reversed phase conditions, it seems fairly likely that the dielectric constant would be low enough to support ion pair formation since the stationary phase should be fairly rich in organic solvent relative to the mobile phase, poorer in water content relative to the mobile phase with the added dielectric constant reducing effect of the bonded phase. If this is so, then perhaps ion pairs actually form as they approach the stationary phase even if they can't form in the mobile phase.
