Page 2 of 2
Re: transfer line from GC column to MS
Posted: Wed Feb 02, 2022 8:36 pm
by soccerdad007
MSCHemist, it sounds like we have something similar to you in terms of this quick swap/backflush set up. Is yours an Agilent system?
A couple of years ago a service engineer from Agilent came by and told us that with experience they had found that having 4 psi He on the line isn’t the way to go. I think they had said 4 psi as a standard when setting up these quick swap fittings initially.
If this is relevant, you could contact Agilent or contact me directly and I will try to remember all the technicalities as to why. We made the changes they proposed and things more reliable
Kevin.
Posted: Thu Feb 03, 2022 5:51 pm
by MSCHemist
Kevin.
That is what is in the Agilent Quickswap manual and I have tested it and it works. I tried unhooking the column while having manual tune open looking at m/z 28, 32, and 18 and found no air coming in.
Also I keep the transferline at 280degC
at 4psi, 0.1mm ID 0.17m length that translates to 1.3 ml/min flow into the MSD. That is optimal when the column flow is 0.9-1.2ml/min
Posted: Tue Aug 09, 2022 1:57 pm
by fcozzi
Kevin.
Thanks!
