Re: Chemstation + Windows 11
Posted: Mon Oct 16, 2023 7:36 am
Thanks for the infoThis is exactly how I explain having Win98, WinNT4, and WinXP on my lab instruments. And VMWare 15 running Win10 on my Win7Pro64 office machine here at work for my quickbooks. I keep all the lab instruments and PC's on a separate subnet with no internet access. Dual NIC's in the office PC let me pull data up to the front for reporting.As for the vendor being responsible for making it work with new OS versions, they will tell you that this software is now obsolete so they do not make fixes for such problems. But also the newer software is not compatible with the older instrument which have been "out of service life" for years. The problem then becomes you need to replace a perfectly working $50,000+ instrument simply because Microsoft changed its OS version.geometry dash online
