Posted: Wed Sep 09, 2009 4:49 pm
Dear HW Mueller,
It looks that you are trying to help me in the best manner. Thanks for this.
I would like to ask you what is your vision for further alteration of chromatographic conditions.
In addition, a selected wavelength of 275 nm corresponds with literature data and the published spectras of naphthalene. If you have some other ideas about the Excitation wavelength, please share them with me. The combination (Excitation/Emission) was chosen due to the higher peak signal of naphthalene. However, the signal does not break world records for size.
I can not remember a method for a sample enrichment of water:acetonitrile solution containing naphthalene (or whatever is there)without using SPE for instance. I belief that using of an additional method for enrichment should not submit new doubt on the obtained results.
Thanks in advance for your valuable comments and suggestions.
