by
dbeerd » Tue Jan 17, 2012 9:08 am
I would like to export all the HPLC-DAD data for a run to an ascii or csv format. In other words all intensity values for each time-point and each wavelength over a range of wavelengths. From the software its possible to export either an chromatogram (intensity values at a single wavelength over time) or a spectrum (intensity values at a single time over a wavelength range).
I found an older post
viewtopic.php?f=4&t=7679 pointing to a macro. Does anyone know where to find this macro as I do not have access to an actual Agilent Chemstation CD. Any other leads on how to perform this data export will also be welcome.
Dalene
