I have a problem with my agilent 1100 system. I am using the chemstation 10.0 rev a.Few days ago, when I try to make pump diagnosis by using the pressure test and the leak test. But I encounter a problem in the Leak Test Evaluation Test Result which it show error. When I check the log book it don't show any error. This evaluation test result error didn't show at he pressure test.
Do you have any idea about this error and how to solve it? I have tried it several time and the error always at the evaluation test result step. The test itself is done and got no problem.
Any suggestion or idea would be appreciated. Thanks.
QA F&B SIF
