For your situation, you can transfer your files to the computer with the newer software (each folder in the \Data directory that ends with .D is an injection. Transfer all the contents of these folders to the new computer and view the files.
Or, you can search for third party suppliers of used ChemStation software. You should be able to purchase an older spectra license for a relatively small fee, although I do not know if it will be less than $500.
ACCTA, Inc.
