ChromQuest/EZChrom Sequences to Queue
Is there a way to add sequences to a ChromQuest queue after the samples in the first sequence have started injecting?
unless you have a very old version or a bug
you simply ask to run the sequence and it is added to the queue
if those are runs from the same sequence then you need to be careful about this since ezchrom is not a date base software it will get stuck because you will have the same file name twice in the same location
