ChemStation report size in pdf
I'm using ChemStation A.10.02 and I'm trying to print my reports using Adobe pdf. The reports appear very small and I need to find a way to print these report files in normal size.
Very strange. Just checked with my A.10.02. Normal size pdf reports are generated.I'm using ChemStation A.10.02 and I'm trying to print my reports using Adobe pdf. The reports appear very small and I need to find a way to print these report files in normal size.
I guess the problem is with pdf printer driver.
I use pdfCreator (as I remember well with default settings).
Before printing to pdf I select pdf creator as specific printer.
Maybe you should check settings of your pdf printer.
Thanks. The problem was with the pdf printer.
