exporting data from Empower 2 to excel
I am trying to export data from Empower 2 to an ACSII file. I was able to generate an export method. and then I went to the results tab, right click any one of the results, choose export with my export method. but nothing was exported to the destination folder.
I am wondering if we need to purchase any extra package to do that.
If no, could any one please tell me how to generate an export method, and use it to export data to various format.
Thanks a lot
Probable issue: Your report file is there, but you are not seeing it because Excel defaults to opening up *.xl* named files. Your report file is *.ars - so set Excel to look for all file types (choose option in the bottom of "Open File" dialog box). It should be there. If not, see below.
An export method just calls up a regular method and ships the data to a user specified file.
Generally, I take an existing sumamry method (just tables) and I strip the headers, footers and page breaks out. Then I do a "save as", naming it whatever_export. I create an export method that (on the Report tab) names the previous method and specifies a path and ascii file name on a local drive (in client server installations, don't save your files on servers).
DR
Probable issue 2: Maybe you tried to export on a mapped network drive?
I tried this this morning and you need to use "\\server\map" instead of "R:\"
good luck
Ace
In total there are 16 users online :: 2 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 14 guests
