Square solvent peak!
Help!
I'm using a GC-FPD for organotin analysis and am getting a large square solvent peak at the outset, which can be very large and produce ugly chromatograms (although it doesn't interfere with my analysis as such). My solvent is iso-octane... Any suggestions?
Rachel :)
Unless the solvent peak is causing quantitation problems, or extinguishing the flame, I would not be concerned - it is common that the solvent overloads the column and detector, which causes a flat-topped peak.
You may find the following link helpful.
http://www.restek.com/fantasia/pdfCache/59550.pdf
Answer Man
If it is significantly larger than what you're used to getting - check for leaks or misprogramming of the injector.
DR
Help!
Rachel :)
:D I have the same thing when i analyse CS2 in isooctan,the solvent peak at the end of the chromatogramm is very large...but don't interfere...
In total there are 46 users online :: 2 registered, 0 hidden and 44 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 44 guests
